Brief Description: Brake line and gear leg fairing installation
Today I installed the brake lines from the fuselage bulkhead fitting to the brake assembly. Then I cut gear leg fairings as per the template on drawing C3. Lastly I cut the gear leg fairing hinges to length and drilled them.
